the AI Hardware Partner
Toggle Nav
Loading...
Skeleton Box 10x10
When you build a Demo, do you want to select a suitable shell for improving whole felling? Skeleton Box 3
$4.00
Out of stock
Skeleton Box 3.0 is the newest version, protection circuit device. There are serveral hool sites in Acrylic floor in order to ensure you can install a variety of circuit boards. When you need to lead wire from side to out, you can open expand hole sites in the acrylic panel.Skeleton Box 3.0 includes three modules: big, middle,small.You can choose modules according to individual requirement. More user experience waits for your participation.
Item
Length Width Height Unit
Skeleton Box 10x7 106 67 36 mm
Skeleton Box 10x10 106 106 36 mm
Skeleton Box 17x10 177 106 36 mm
Assembling Instructions
Dimensions 160mm x130mm x28mm
Weight G.W 139g
Battery Exclude
HSCODE 9023009000
UPC 841454103028
COO CHINA
RoHS 1
  1. Product Quality
    80%
    Nice little box I like these boxes and actually put them side way (i.e. the 10x10 facing front) so that I can plan LED display there. One this I like to change is the PCB actually has the LED through power pins (with resistors), which is limiting. If they are connected to signal, then I don't have to hack it (connect to GPIO so I can turn on/off the light). Grove connectors are nice but the one on ether reverse side are pretty much useless. I think some changes will make this product better.
    By
1 Item
Show per page
