the AI Hardware Partner
Toggle Nav
Loading...
3D Printer ABS Filament - Original
Rating:
100 % of 100
ABS is a polymerized styrene comprised of acrylonitrile, butadiene and styrene
$30.00
Out of stock
  • 10+: $27.00
ABS is a polymerized styrene comprised of acrylonitrile, butadiene and styrene. Acrylonitrile and styrene gives ABS rigidity and shiny surface. Polybutadiene gives it toughness and impact strength. Aside from these qualities, ABS performs a better flowability when melting and resists corrosion and abrasion as well. These qualities combined make it an ideal material for injection mold and extrusion.
ABS is a recommended material for beginners by RepRap because of the loose temperature requirement during extrusion process.
This material has been tested on RepRap, Makerbot, Mendel, Huxley UP! Printer, WeisTek, Thing-o-matic and Ultimaker.
Note: This product is priced for 1 spool (including 1kg filament), and free shipping policy is NOT apply to the 3D Printer Filament.
  • Loose temperature requirement
  • Good flowalibity
  • Easy to shape
Specifications
  • Print temperature: 220°C to 245°C
  • First layer temperature: 235°C
  • Print base material: Acrylic/ABS
  • Diameter: 1.75mm
Dimensions 0mm x0mm x0mm
Weight G.W 1170g
Battery Exclude
HSCODE
UPC 841454114604
COO CHINA
  1. Product Quality
    100%
    By
1 Item
Show per page
