XC9572XL CPLD development board v1b
Rating:
60% of 100
Ever get stuck choosing the right logic chip combination or voltage level translator? Give up the hunt and create your own custom logic chip
$12.90
Out of stock
Ever get stuck choosing the right logic chip combination or voltage level translator? Give up the hunt and create your own custom logic chip. CPLDs can give you the logic you need, with the pinout you want, while saving board space and board revisions.
The Xilinx XC9500XL family has some of the cheapest and readily-available CPLDs. This development board from Dangerous Prototypes will help you build your first custom logic chip using simple schematic entry, Verilog, or VHDL.
  • XC9572XL CPLD with 72 macrocells
  • 5volt tolerant inputs
  • On-board 3.3volt power supply for core and pins
  • Selectable 3.3volt or external supply for pins (1.8volt to 3.3volt)
  • LEDs for output
  • Push button for input
  • Populated JTAG header
  • Easy to program with the Bus Pirate
  • Open source (CC-BY-SA)
Resource
Techsupport
This product is designed by Dangerous, If you encounter any problems when using this product, please request technical support in the forum.
Dimensions 52mm x29mm x11mm
Weight G.W 8g
Battery Exclude
XC9572XL CPLD development board v1b 1
HSCODE 8504909000
USHSCODE 8504902000
UPC 841454101024
Product Faqs
Sort by
