Loading...
Barometer Module - .NET Gadgeteer Compatible
This product can now be purchased at www
$33.00
Out of stock
This product can now be purchased at www.ghielectronics.com.
Barometer Sensor module for Gadgeteer. This module is used for atmospheric pressure, altitude and temperature sensing . A sensor HP03M, which measures the pressure based on a piezoresistive pressure sensor, was equipped on this module, and provides accurate pressure and temperature data to Gadgeteer mainboard via I2C bus.
Requires socket type I.
  • Gadgeteer socket type I
  • Base on piezoresistive sensor
  • -40 °C ~+8 °C operating range
External Links
you need to download the following software to start your Gadgeteer:
  1. Development tool : Microsoft Visual C# Express 2010
  2. Micro framework: Microsoft .NET Micro Framework 4.1 SDK
  3. The Gadgeteer core, mainboard SDk and module driver(GHI)
You can download these tools at : http://tinyclr.com/support
Dimensions 0mm x0mm x0mm
Weight G.W 6g
Battery Exclude
HSCODE
Documentations
Learn
