the AI Hardware Partner
Toggle Nav
Loading...
BlueStack Micro+ (iOS version)
Dvmega, radio, ham, rpi, hotspot, dstar, dmr, fusion, uhf, GMSK, repeater, vhf, ble, app, android, ios,
$29.00
In stock
Bluestack board, supports DVMEGA raspberry Pi – boards (not included), both dual and single band. With the BlueDV app, you have access to:
  • via Bluetooth: DMR and Fusion, NO DSTAR!!
  • via Windows or Linux (USB): DSTAR, Fusion and DMR.
IOS version Bluetooth ONLY
- Switch activated (in), serial mode for Jonathan Naylor (G4KLX mode), MMDVM, BlueDV for Windows, or DVMEGA firmware upgrade mode via X-loader tool.
Note: new units will be switching off programming-mode after 1 minute. This is for MMDVM-mode. Older units; disconnect the wire on radio board after upgrade. Download the needed firmware for the DVMega board HERE!
- Switch de-activated (out), BlueDV mode, connecting to BlueDV App. BlueDV is an IOS app, so perfect to use as mobile hotspot!!
NOTE: NO DSTAR SUPPORT YET.
Unit is always powered through the micro usb, so use an adaptor or a battery-pack to power, or just power via the PC/USB-hub.
If you want BlueStack Andorid version, please visit here.
Dimensions 97mm x80mm x15mm
Weight G.W 13g
Battery Exclude
BlueStack Micro+ (Ios version) 1
HSCODE 8543909000
USHSCODE 8543708800
UPC 841454120148
EUHSCODE 8543709099
COO Netherlands
RoHS 1
