DSCope
Rating:
40% of 100
An open source USB-based oscilloscope Pocket size (101mm*74mm*16mm) Experiments, electronics maintenance, academic and engineering task
$199.00
In stock
  • 10+: $189.05
DSCope is an open source USB-based oscilloscope. It's specially designed for makers with professional specifications and an affordable price. DSCope can be used in academic, experiment, electronics maintenance, engineering task etc.
DSCope has a pocket size (101mm*74mm*16mm), which make it to be an ideal replacement to clunky traditional oscilloscope, and help you to save a big area for your working desktop.
DSCope works with your PC, MAC or even windows tablet through USB interface, which bring a big screen oscilloscope to you without any extra cost.
  • Open source
  • Unibody aluminum shielded case
  • Auto zero skew adjustment
  • upgradable Hardware
  • Advanced digital trigger
  • Deep sample depth
  • USB interface, USB powered
  • Two channels
  • Signal Generator
  • Analog Bandwidth: 50MHz
  • Max Sample rate: 200MHz @ 1 Channel / 100MHz @ 2 Channels
  • Max Sample Depth: 1M(real-time mode) / 16M(single mode)
  • Coupling: AC / DC / Ground
  • Input Characteristics: 1MΩ // ~15 pF
  • Protected Voltage: ±100 V (DC+AC peak)
  • Vertical Sensitivity: 10mV/div ~ 2V/div (x1) / 100mV/div ~ 20V/div (x10)
  • Horizontal Sensitivity: 10nS/div ~ 10S/div
  • Triggering Mode: Auto, Single, And, Or
  • Rising/Falling Edge trigger
  • Vertical precise, horizontal precise measurement
  • Waveform functions auto measurement: max, min, frequency, period
  • Support OS: windows, Linux, OS X
  • Dimension: 101 x 74 x 16 mm
Support
This product is designed by DreamSourceLab, for any document and techsupport, please go to:
Dimensions 180mm x110mm x45mm
Weight G.W 393g
Battery Exclude
DSCope 1
USB cable 1
P6100 probes 2
Adjustment tool 1
HSCODE 9030201000
USHSCODE 90302010
UPC 841454110378
Customer Reviews
  1.
    Rating
    40%
    Its software is very poor.
    Review by
    Posted on
Product Faqs
Sort by
