DSO Touch
Rating:
80% of 100
Pocket-size open source 32bit digital storage oscilloscope Touch screen Two channels with max sample rate: 10MSa/s
$99.00
Out of stock
DSO Touch, is a 2 channels digital pocket size oscilloscope. It is only 10mm thick with an aluminum alloy appearance. How a compact and fashionable tool! The touch screen is 320x240 color display. It support SD card USB flash disk storage and USB charging. DSO Touch can be used in academic, experiment, electronics maintenance, engineering task etc.
  • Pocket size and light
  • Touch screen
  • Two channels
  • Signal Generator
  • ŸVarious Triggering Option
  • Easy waveform storage
  • Analog bandwidth: 1MHz
  • Max sample rate: 10MSa/s
  • ŸMax sample memory depth: 8K
  • Analog input impedance: 1MΩ
  • Max input voltage: ±40V (X1 probe)
  • Couling: AC/DC
  • Vertical Sensitivity: 20mv/Div ~ 10V/Div (stepping in by 1-2-5 mode)
  • Horizontal sensitivity: 1uS/Div ~ 2S/Div (1-2-5 stepping)
  • Math waveforms: -A,-B; A+B; A-B; RecA, RecB, RecC
  • Triggering Mode: Auto, Normal, Single, Noce, Scan
  • Rising/Falling Edge Trigger
  • Vertical precise, horizontal precise measurement
  • Waveform functions auto measurement: frequency, cycle time, duty cycle, peak voltage, RMS voltage, Average voltage and DC voltage
  • Signal Generator/10Hz ~ 1MHz square wave (duty adjustable) or 10Hz ~ 20KHz Sine/Square/Triangle/Sawtooth wave
  • U disk waveform storage of 8MB, can store waveform data and waveform image
  • Power supply internal 550mAh lithium battery, external USB port
  • Display full color TFT LCD (320x240 pixels)
  • Capacitive touchscreen: support input by finger sliding
  • Dimension: 100 x 56.5 x 10.7 mm
  • DSO Touch x 1
  • Spare probe x 2
  • Metal Stand x 1
  • ŸSack x 1
  • ŸMicro USB Cable x 1
  • Screw x 1
  • ŸDSO Touch User Manual x 1
Documents
  • For technical support and suggestions, please visit our forum.
  • Please click here to download the User Manual of DSO Touch, and please note that "DSO 202" in the User Maual is the same thing as DSO touch, only different in naming.
Dimensions 157mm x84mm x55mm
Weight G.W 326g
Battery Lithium Cells / Batteries contained in equipment UN3481 - PI967
HSCODE 9030201000
USHSCODE 90302010
UPC 841454110279
FCC 1
CE 1
Customer Reviews
  1.
    Rating
    80%
    Nice, inexpensive tool A little quirky, but a nice tool once you get used to it. Price for what it does is hard to beat.
    Review by
    Posted on
Product Faqs
Sort by
