Loading...
Digital Capacitance Meter
3 1/2 LCD, nine ranges from 200pF to 20000uF, this digital capacitance meter is of high of accuracy in measuring and of reading
$34.90
Out of stock
  • 10+: $31.41
  • 20+: $29.67
3 1/2 LCD, nine ranges from 200pF to 20000uF, this digital capacitance meter is of high of accuracy in measuring and of reading. It includes all capacitance in electronic engineering lab, production lines, maintenance points and education. Driven a battery, its compact structure and light weight makes it a truly pocket-sized instrument. It features low power consumption, LCD display, convenience, accurate measurement and readings, wide measuring range. Even in bright place, it can show a clear reading; measurement accuracy. The LSI application provides the instrument with characteristics such as, high reliability and durability, low battery indication, and fast sampling characteristics etc.
  • Low power, backlight display
  • High measurement accuracy, wide measurement range
  • High reliability and durability
  • Low battery indication, fast sampling
  • Overload protection
  • Zero adjustment (manually)
Specifications
  • Electrical Characteristics
RANGEMAX. DISPLAYRESOLUTIONFREQUENCYACCURACY
200pF199.9pF0.1pF800Hz±(0.5%+7)
2nF1.999nF1pF800Hz±(0.5%+5)
20nF19.99nF10pF800Hz±(0.5%+5)
200nF199.9nF100pF800Hz±(0.5%+5)
2uF1.999uF1000pF800Hz±(0.5%+5)
20uF19.99uF0.01uF800Hz±(0.5%+5)
200uF199.9uF0.1uF8Hz±(0.5%+5)
2000uF1999uF1uF8Hz±(2%+5)
20000uF1999( x 10)uF10uF8Hz±(3%+10)
  • Others
MAX. DISPLAY1999(3 1/2bit LCD display)
COVERSION RATE(0~5)second
WORKING CONDITION0℃~40℃, <80%RH
BATTERY LIFEAbout 200 hour of normal operation
DIMENSION189x97x35mm
Package Including
  • Digital Multimeter
  • A pair of probe cables
  • Black Bag
  • Measuring connector
Dimensions 0mm x0mm x0mm
Weight G.W 612g
Battery Exclude
HSCODE
Documentations
Learn
