RF Explorer RFEMWSUB1G Module
Easy to plug in your RF Explorer unit, compatible with all models Extend band coverage to all popular sub-1Ghz ISM bands Extend internal FLASH and RAM memory for additional capabilities
$55.00
In stock
  • 50+: $49.50
RFEMWSUB1G is an Expansion Module for RF Explorer. It can be plugged in your RF Explorer unit to extend the coverage to 240-960Mhz frequency band.
It gets attached internally to the RF Explorer main board and exhibits a second antenna connector to cover the new band.
Feature
  • Easy to plug in your RF Explorer unit, compatible with all models
  • Extend band coverage to all popular sub-1Ghz ISM bands, including 315Mhz, 433Mhz, 868Mhz and 915Mhz, also including UHF TV, 70cm and 33cm HAM radio, etc. Any frequency from 240Mhz to 960Mhz is covered.
  • Extend internal FLASH and RAM memory for additional capabilities
  • Lifetime free firmware upgrades available, open to community requested features
  • For detailed instructions please visit www.rf-explorer.com/expansion
Important: Note this unit does not include RF Generator functionality, only Spectrum Analyzer functionality is available
  • Frequency band coverage: 240-960 MHz
  • Standard SMA 50 ohms connector
  • Amplitude resolution: 0.5dBm
  • Dynamic range: -115dBm to 0dBm
  • Absolute Max input power: +5dBm
  • Average noise floor level (typical): -110dBm
  • 50 ohms wideband dual band telescopic 144/430MHz telescopic antenna included
  • Frequency stability and accuracy (typical): +-10ppm
  • Amplitude stability and accuracy (typical): +-3dBm
  • Frequency Span: 100MHz
  • Frequency resolution: 1Khz
  • Resolution bandwidth (RBW): automatic 3KHz to 600KHz
Techsupport
This product is designed by RF-Explorer,
  • For more info and to get started with your RF Explorer, visit the start page.
  • For questions and support, please visit https://support.rf-explorer.com.
  • For the software for RF Explorer series, please click the following logo for more information:
Dimensions 145mm x100mm x15mm
Weight G.W 58g
Battery Exclude
RFEMWSUB1G Module 1
SMA 50 ohms connector 1
Antenna 1
HSCODE 9030900090
USHSCODE 9030890100
UPC 841454103844
ROHS 1
Product Faqs
Sort by
