Loading...
Renbotics ServoShield V2.0
The Renbotics Servo Shield Rev 2 is an Arduino-compatible shield that uses only two pins to drive 16 servos per shield
$16.95
Out of stock
The Renbotics Servo Shield Rev 2 is an Arduino-compatible shield that uses only two pins to drive 16 servos per shield. The Renbotics Servo Shield Rev 2 uses a PCA9685 over I2C to provide 16 free-running servo outputs. The address of the board is selectable via a DIP switch making it easy to stack up to 62 shields to control up to 992 servos. Two jumpers make it easy to select the Arduino host model used.
  • 16 Servo Channels
  • Convenient screw terminal for servo power supply
  • 196 Point breadboard style prototyping area
  • Compatible with Arduino Duemilanove, UNO, Leonardo and Arduino Mega 2560
  • Dip switch to easily set and/or change address
  • 50Hz or 60Hz mode
  • Easy to use API
Applications
  • Robotics
  • Animatronics
  • Mechatronic Art
Parts List
  • Renbotics Servo Shield Rev 2 PCB with all surface mount components x 1
  • 10 pin Female Stacking Header x 1
  • 8 pin Female Stacking Headers x 2
  • 6 pin Female Stacking Headers x 2
  • 2 pin Screw Terminal x 1
  • 8 pin Male Breakaway Headers x 6
  • 3 pint Male Breakaway Headers x 2
  • Jumpers x 2
Dimensions 0mm x0mm x0mm
Weight G.W 25g
Battery Exclude
HSCODE
