XMEGA Xminilab
Rating:
100% of 100
Mixed Signal Oscilloscope Horizontal and Vertical Cursors for measurement Advanced Trigger
$69.00
In stock
  • 10+: $68.00
The Xminilab is a mixed signal oscilloscope with an arbitrary waveform generator in a DIP module. It measures only 3.3 x 1.75 inches, and can be mounted directly on a breadboard. The Xminilab can also be used as a development board for the AVR XMEGA microcontroller.
  • Mixed Signal Oscilloscope: Simultaneous sampling of analog and digital signals.
  • Advanced Trigger: Normal / Single / Auto, with rising or falling edge and adjustable trigger level.
  • Meter Mode: Average, Peak to peak and Frequency readout.
  • XY Mode (Plot Lissajous patterns or see the phase difference between two waveforms).
  • Spectrum Analyzer with different windowing options and selectable vertical log.
  • Horizontal and Vertical Cursors with automatic waveform measurements.
  • Arbitrary Waveform Generator with Sweep on all parameters.
  • Display options: Persistence, Different grid options, and more.
General Specifications
  • ATXMEGA32A4U 36KB Flash, 4KB SRAM, 1KB EEPROM
  • Graphic OLED display 2.42", 128x64 pixels
  • Module size: 3.3" x 1.75"
  • PDI interface.
  • 4 tactile switches
  • USB connectivity: Windows, Linux, MAC, Android
Logic Analyzer specifications
  • 8 Digital Inputs, 3.3V level.
  • Maximum sampling rate: 2MSPS
  • Frequency counter: 16Mhz
  • Protocol Sniffer: UART, I2C, SPI
  • Internal pull up or pull down.
  • Buffer size: 256
Oscilloscope specifications
  • 2 Analog Inputs
  • Maximum Sampling rate: 2MSPS
  • Analog Bandwidth: 200kHz
  • Resolution: 8bits
  • Input Impedance: 1M
  • Buffer size per channel: 256
  • Input Voltage Range: -14V to +20V
AWG specifications
  • 1 Analog Output
  • Maximum conversion rate: 1MSPS
  • Analog Bandwidth: 44.1kHz
  • Resolution: 8bits
  • Output current > +/- 7mA
  • Buffer size: 256
  • Output Voltage: +/- 2V
Documents
Dimensions 120mm x80mm x16.5mm
Weight G.W 33g
Battery Exclude
HSCODE 8517703000
UPC 841454101017
Customer Reviews
  1.
    Rating
    100%
    Review by
    Posted on
  2.
    Rating
    100%
    Review by
    Posted on
Product Faqs
Sort by
