the AI Hardware Partner
Toggle Nav
Loading...
Xminilab Portable
The Xminilab Portable is a small mixed signal oscilloscope with an arbitrary waveform generator and protocol sniffer
$118.00
Out of stock
  • 10+: $112.10
The Xminilab Portable is a small mixed signal oscilloscope with an arbitrary waveform generator and protocol sniffer.
Features:
  • Mixed Signal Oscilloscope: Simultaneous sampling of analog and digital signals.
  • Advanced Trigger: Normal / Single / Auto, with rising or falling edge and adjustable trigger level.
  • Meter Mode: Average, Peak to peak and Frequency readout.
  • XY Mode (Plot Lissajous patterns or see the phase difference between two waveforms).
  • Spectrum Analyzer with different windowing options and selectable vertical log.
  • Horizontal and Vertical Cursors with automatic waveform measurements.
  • Arbitrary Waveform Generator with Sweep on all parameters.
  • Display options: Persistence, Different grid options, and more.
  • Curve tracer function
Specifications:
General Specifications:
  • ATXMEGA32A4U 36KB Flash, 4KB SRAM, 1KB EEPROM
  • Graphic Green OLED display 2.42", 128x64 pixels
  • Enclosure size: 3.17" x 2.22" x 0.7"
  • Li-Ion Battery 750mAh
  • PDI interface.
  • 4 tactile switches
  • USB connectivity: Windows, Linux, MAC, Android
Logic Analyzer specifications:
  • 8 Digital Inputs, 3.3V / 5V
  • 820k ohm input impedance
  • Maximum sampling rate: 2MSPS
  • Frequency counter: 16Mhz
  • Protocol Sniffer: UART, I2C, SPI
  • Internal pull up or pull down.
  • Buffer size: 256
Oscilloscope specifications:
  • 2 Analog Inputs
  • Maximum Sampling rate: 2MSPS
  • Analog Bandwidth: 200kHz
  • Resolution: 8bits
  • Input Impedance: 1M惟 15pF
  • Buffer size per channel: 256
  • Input Voltage Range: -14V to +20V
AWG specifications:
  • 1 Analog Output
  • Maximum conversion rate: 1MSPS
  • Analog Bandwidth: 50kHz
  • Resolution: 8bits
  • Output current > +/- 7mA
  • Buffer size: 256
  • Output Voltage: +/- 4V
Documents:
For any technical support or suggestion, please kindly go to our forum.
Dimensions 0mm x0mm x0mm
Weight G.W 183g
Battery Lithium Cells / Batteries contained in equipment UN3481 - PI967
HSCODE 9030201000
