Cordless Power Precision Screwdriver
Wowstation 1FS is an innovative potable coreless power screwdriver for home appliances, electronics with an elegant and modern design, simple and convenient to use.
This screwdriver has an aluminum alloy housing and is easy to grip. The forward and reverse rocker switch lets you easily control. It also built-in 2xAAA batteries can work 8 hours continuously with lighting.
It comes with 1 x Screwdriver Head Extension Rod and 6 x popular bits Bits: PH0000, PH1, SL1.5, SL3.0, T5, T6. A quick-change chuck makes changing bits easy on this power screwdriver. The chuck is compatible with all micro (4mm) bits.
Dimensions | 255mm x55mm x40mm |
Weight | G.W 251g |
Battery | Lithium Cells/Batteries packed with equipment UN3481 -PI966 |
Color | Silver |
Led light | Yes |
Length | 17 cm |
Net weight | 177 g |
Power Supply | 2x AAA Battery |
Torque | 0.2/3N.m |
Speed | 100RPM + or - 10% |
Working Time | Approx 8 to 24 Hours |
Batch Head Size | 4x 28mm |
Screwdriver Bit Size | PH0000, PH1, SL1.5, SL3.0, T5, T6 |
Rotation | Forward, reverse and self-locking |
Wowstick 1fs Electric Screwdriver | 1 |
White Package Box | 1 |
60mm Extension Rod | 1 |
Standard Screwdriver Bits | 6 |
AAA Battery | 2 |
HSCODE | 8467299000 |
UPC | 841454119760 |
