the AI Hardware Partner
Toggle Nav
Loading...
16x16 RGB LED Matrix w& WS2812B - DC 5V
16*16 Digital RGB LED Matrix is consist of WS2812B RGB LED
$89.00
Out of stock
  • 10+: $80.10
  • 20+: $75.65
  • More
  • 50+: $71.20
  • Less
16*16 Digital RGB LED Matrix is consist of WS2812B RGB LED. WS2812B is a 5050 components that integrate control circuit and RGB chip in a package.
The LED Matrix are placed 16 Pixels each line, and there are 16 lines on each panel. The space between each pixel is 1cm.
Feature
PIN Function:
No.
Symbol
PIN
Function Description
1
+5V
Power
5V power supply
2
DIN
Data Input
Input the control signal
3
GND
Ground
Earthing
4
DOUT
Data Output
Output the control signal, and connect to next panel’s DIN
RGB Parameters
Color
Model
Wavelength(nm)
luminous intensity(mcd)
operating voltage(V)
Blue
13CBAUP
465-467
180-200
3.0-3.4
Green
13CGAUP
522-525
660-720
3.0-3.4
Red
10R1MUX
620-625
390-420
2.0-2.2
Data Transfer (TH+TL=1.25µs±600ns)
T0H
Code 0, High level
0.4µs
±150ns
T1H
Code 1, High level
0.8 µs
±150ns
T0L
Code 0, Low level
0.85µs
±150ns
T1L
Code 1, Low level
0.45 µs
±150ns
RES
Low level
>50µs
Timing Waveforms
Input Code:
Connection Method
LED Quantity 256
IC Type WS2812 (IC Built in LED)
Wattage 78.6W/M
Pixel/m 16*16
PCB Width 16*16cm
Length of cable 100mm
Working Voltage DC 5V
PCB Color black
Light Color Multi-Color, digital RGB,Every LED individual Contro
WS2812 Datasheet
HC-F5V-256 Screen Datasheet(HC-F5V-256 Screen Datasheet.pdf)
Dimensions 160mm x160mm x16mm
Weight G.W 96g
Battery Exclude
HSCODE 8531200000
ROHS 1
