8x8 RGB LED Dot Matrix - Compatible with Rainbowduino
Do you know how is the cool advertising display made? It is exactly composed of these small RGB LED matrix
$18.50
In stock
  • 10+: $16.65
  • 20+: $15.73
  • More
  • 50+: $14.80
  • Less
Do you know how is the cool advertising display made? It is exactly composed of these small RGB LED matrix. If you want to make a similar display, this RGB LED matrix will meet you need. The 8x8 LED matrix has 32 of pins, you may need a driver to control it. It sounds quite complex, but don't worry, we have provided a driver board Rainbowduino for this LED matrix as your reference. Make it easy for you to start your project.
  • Fully compatible with Rainbowduino
  • Full color RGB variation
  • Circular LED point source
Specifications (IF = 20mA)
  • Forward voltage(RED): DC 2.2V
  • Forward voltage(GREEN): DC 3.3V
  • Forward voltage(BLUE): DC 3.3V
  • Luminous intensity(RED): 140mcd
  • Luminous intensity(GREEN): 280mcd
  • Luminous intensity(BLUE): 80mcd
  • Wavelength(RED): 620~622.5nm
  • Wavelength(GREEN): 520~522.5nm
  • Wavelength(BLUE): 465~467.5nm
Documents
Dimensions 65mm x90mm x18mm
Weight G.W 31g
Battery Exclude
HSCODE 8531200000
UPC 841454112419
ROHS 1
Product Faqs
Sort by
