8x8 RGB LED Matrix - Square LED Dot
Rating:
80% of 100
This a new 8x8 RGB LED matrix, also compatible with Rainbowduino
$11.90
Out of stock
  • 10+: $10.71
  • 20+: $10.12
  • More
  • 50+: $9.52
  • Less
This a new 8x8 RGB LED matrix, also compatible with Rainbowduino. Compare to the old 8x8 RGB LED matrix, this new LED matrix features square LED dot and its only half thickness.
Features:
  • Fully compatible with Rainbowduino
  • Full color RGB variation
  • Square LED point source
  • Ultrathin
Specification:
  • Dot Size: 5.0mm
  • Pixel Array: 8×8
  • Luminous Intensity: 40mcd
  • Package Dimension: 60mm×60mm
  • Reverse Voltage(Max): 5V
  • Forward Current(Max): 25mA
  • Peak Forward Current(Max): 100mA
  • Power Dissipation(Max): 100mW
  • Operating Temperature(Max):-35~+85℃
  • Storage Temperature(Max): -35~+85℃
  • Lead Solder Temperature(Max): 260℃ for 5 seconds
Compatibility:
Document:
Dimensions 88mm x88mm x13.8mm
Weight G.W 24g
Battery Exclude
HSCODE 8531200000
UPC 841454120445
Product Faqs
Sort by
