Loading...
EL Panel - Blue 10cm x 10cm
A big sister to our EL tape, the EL panel is a similar item that comes in a 10 cm square format
$8.90
Out of stock
  • 10+: $8.01
  • 20+: $7.57
  • More
  • 50+: $7.12
  • Less
A big sister to our EL tape, the EL panel is a similar item that comes in a 10 cm square format. You’ll notice when working with it that it shares some of the same features as the EL tape: flexibility, portability, and a beautiful soft glow. It can be used as backlight for an illuminated device, or a platform for paper-cutting artwork. Post it on a flat surface or wrap it around a curved surface. Use it in a project as a lighting element or attach it to a shirt. The options are amazing.
You need an inverter to drive the EL light, to control it, please pick up an EL Shield.
  • No heat loss
  • Great backlight material
  • High efficiency (97%)
  • Does not emit UV light
  • Soft light that is not harsh on the eyes
  • Waterproof, except the connecter
  • The higher voltage EL USB inverter is recommended because it produces a stronger light
  • Able to be cut into other shape
Specifications
  • Dimension: 10 cm x 10 cm
  • Thickness: 0.4 mm - 1.0 mm
  • Operating Voltage: 100 V~ 220 V Optimum : 120 V
  • Operating Frequency: 50 Hz~ 5000 Hz Optimum: 1500 Hz - 2000 Hz
  • Static Capacitance: 6 nf/m (20 ° C, the RH <80%)
  • Brightness: 30 cd/m2 ~ 126 cd/m2 (at 120 V, 200 Hz ~ 2000 Hz)
  • Power: 108 mw m ~ 1032 mw/m (at 120 V, 200 Hz ~ 2000 Hz)
  • Life: approximately 8000 hours
  • Operating Temperature/Humidity: -10 °C ~ + 60 °C/RH < 90%
  • Storage Temperature/Humidity: -10 °C ~ + 60 °C/RH < 65%
Dimensions 135mm x110mm x6.8mm
Weight G.W 11g
Battery Exclude
Documentations
Learn
