the AI Hardware Partner
Toggle Nav
Loading...
Grove - Variable Color LED
Rating:
100 % of 100
This product consists of one 8mm RGB LED. It operates at 5V DC. When SIG pin is logic LOW, the RGB LED will show.
$3.90
Out of stock
  • 10+: $3.51
This product will EOL soon, please consider the Grove - Variable Color LED V1.1 as alternative choice. Thank you!
This product consists of one 8mm RGB LED. It operates at 5V DC. When SIG pin is logic LOW, the RGB LED will show. Perfect for use on Seeeduino digital outputs, or also can be controlled using pulse-width modulation. And uses three adjustable resistor to change the color of the RGB LED.
For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your using of the product.
Dimensions 130mm x90mm x19mm
Weight G.W 7g
Battery Exclude
Grove - Variable Color LED 1
Grove Cable 1
HSCODE 8531909000
UPC 841454107385
COO CHINA
RoHS 1
Documentations
  1. Product Quality
    100%
    By
  2. Product Quality
    100%
    Great indicator LED They work as expected
    By
2 Item(s)
Show per page
