the AI Hardware Partner
Toggle Nav
Loading...
RPLiDAR A1M8 360 Degree Laser Scanner Kit - 12M Range
RPLIDAR A1 is a low cost 360-degree 2D laser scanner (LIDAR) solution developed by SLAMTEC. The system can perform a 360degree scan within a 6meter range. The produced 2D point cloud data can be used in mapping, localization, and object/environment modeling.
Note: This product has been replaced by an upgraded version, RPLiDAR A1M8-R6. Click here for more details.
Attention
The product page is updated.Please click on the latest product link "RPLiDAR A1M8-R6" to purchase.
  • Measures distance data in more than 8000 times/s
  • 360 Degree Omnidirectional Laser Range Scanning
  • 8000 times sample rate, the highest in the current economical LIDAR industry
  • OPTMAG Original Design, prolong the life-span
  • Configurable Scan Rate from 2-10Hz
  • Ideal for Robot Navigation and Localization
  • Plug and Play
RPLIDAR A1’s scanning frequency reached 5.5 Hz when sampling 360 points each round. And it can be configured up to 10 Hz maximum.
RPLIDAR A1 is basically a laser triangulation measurement system. It can work excellently in all kinds of indoor environments and outdoor environments without sunlight.
For your convenience, we made a table comparing different RPLiDARs so you can easily pick one that suits your project!
Item Measurement Performance
Distance Range Measurement Resolution Angular Resolution Sample Rate Working Environment
RPLIDAR A1M8 - R6 0.15m -12m <0.5 mm <1% of actual distance * ≤1° 2000 – 8000 Hz Indoor
RPLIDAR A2M6 0.2m – 18m <0.5 mm <1% of actual distance * ≤0.9° 2000 – 8000 Hz Indoor
RPLIDAR A2M8 0.15m -12m <0.5 mm <1% of actual distance * ≤0.9° 2000 – 8000 Hz Indoor
RPLIDAR A3M1 White Objects:25 m Black Object: 10 m 0.225° 16 kHz or 10 kHz Indoor & Outdoor
RPLIDAR S1 White Objects: 40m Black Object: 10m 3cm 0.313°-0.587° 9200 Hz Indoor & Outdoor
RPLIDAR S2 White Objects: 30m Black Object: 10m 5cm 0.12° 32 kHz Indoor & Outdoor
SLAMTEC MAPPER M1M1 20m 5cm 7000 Hz Indoor & Outdoor
SLAMTEC MAPPER M2M1 40m 5cm 9200 Hz Indoor & Outdoor
Application Scenarios
  • Home service /cleaning robot navigation and localization
  • General robot navigation and localization
  • Smart toy’s localization and obstacle avoidance
  • Environment scanning and 3D re-modeling
  • General simultaneous localization and mapping (SLAM)
Dimensions 98.5mm x70mm x60mm
Weight G.W 170g
Battery Exclude
Distance Range 0.15 - 6m,White objects
Angular Range 0-360 Degree
Distance Resolution <0.5mm
Angular Resolution ≤1Degree
Sample Duration 0.5ms
Sample Frequency 2000~2010Hz
Scan Rate 1~10Hz,Typical 5.5Hz,
RPLIDAR A1(PWM motor driver embedded) 1
USB Adapter 1
RPLIDAR A1 communication cable 1
HSCODE 9031900090
USHSCODE 9026104000
UPC 841454121244
EUHSCODE 9013101000
COO CHINA
RoHS 1
  1. Product Quality
    100%
    Documentation
    100%
    from order view
    This user did not leave any comments.
    By
  2. Product Quality
    100%
    Nice
    Arrived on time, works perfectly
    By
  3. Product Quality
    100%
    Perfect for small robotic projects
    Excellent product for the price. Although I have not tested it yet, the quality and characteristics look very promising.
    By
  4. Product Quality
    80%
    Works well and easy to use
    Easy to install and use. Comes with good documentation and libraries are available. it produces accurate results. Minor point is that the communication cable sticks out the bottom, which makes propping it up necessary as the legs are a bit short.
    By
  5. Product Quality
    100%
    Strong Performance
    Though the drivers and documentation are not the strongest, the hardware itself and overall refresh rate have been quite satisfactory. Our team is getting good results tracking bodies and with connecting multiple lidar units at the same time.
    By
Items 1 to 5 of 8 total
Page
Show per page
