the AI Hardware Partner
Toggle Nav
Loading...
eNet-ZBP113 ZigBee Module
Introduction: eNet-ZBP113 ZigBee module is a 2
$21.95
Out of stock
Introduction:
eNet-ZBP113 ZigBee module is a 2.4-GHz, IEEE 802.15.4/ZigBee embedded wireless module built in TICC2530, designed by BestU. eNet-ZBP113 module works on global ISM 2.4GHz toll free frequency band with traffic rate reaching 250kb, which can be divided 16 channels.This module is compatible with Raspberry Pi Model B and B+ and Beaglebone Black.
Self-network, LAPU are the main features of eNet-ZBP113 module. It is not necessary for you to understand complex ZigBee Protocol. All the processing part of ZigBee Protocol can be done internally under eNet-ZBP113 module, what you only need to do is to transport data by serial port, which can shorten product lead time tremendously. Meanwhile has the advantage of low-power and low-cost. As a consequence, eNet-ZBP113 module is the best choice of remote monitoring application, such as Smart Home controlling, Smart Grid data collection, industrial automation control and security monitoring and etc.
Features:
Typical DC Character (VDD = 3.3V @ + 25℃)
mA (TXD)
120mA (Max)
mA (RXD)
40mA (Max)
mA (Standby)
35mA (Max)
Typical RF Character
Frequency Range
2.405GHz – 2.480Ghz
RF Channel Number
16
Transfer Rate
250 Kbps
Rx Sensitivity
-97dBm
TX Power
10-20 dBm
Outout Impedance
50 ohm
Typical Networking Character
Wireless Protocol
ZigBee 2007
Largest Network Node
65535 (Max)
Configured Node
Coordinator / Router
Maximum Transmission Distance
1600 meter
Network Topology
Mesh Network (MESH)
Specification:
Package List:
  • eNet-ZBP113 module x 1
  • 2.4G Antenna x 1
Documents:
If you have any technical problem, please contact support [at] bestni.com
Dimensions 0mm x0mm x0mm
Weight G.W 14g
Battery Exclude
HSCODE 8517707090
