Loading...
L3D Cube (8x8x8 Full Color Kit)
Rating:
100% of 100
a full color 8x8x8 LED cube that shows brilliant images and animations in 3D Easier to assemble and no soldering required Built-in microphone for insane music visualizations open-source
$399.00
Out of stock
  • 10+: $359.10
  • 20+: $339.15
  • More
  • 50+: $199.00
  • Less
The L3D Cube is a 3D LED display that will blow your MIND! 512 RGB LEDs in a 8x8x8 array. Works out of the box. 100% open-source. Programmable over your home's wifi. Built-in microphone for INSANE music visualizations. This is the top selling 8x8x8 3D LED Cube kit in the world with an ever-expanding collection of 3D LED Cube apps at CubeTube.org.
L3D Cube: Your First Volumetric Display from Looking Glass on Vimeo.
  • The L3D Cube is a full color 8x8x8 LED cube that shows brilliant images and animations in 3D.
  • Easier to assemble than an Ikea shelf! Takes just 30 minutes, no soldering required.
  • No programming required to get started -- just assemble and plug it in. Comes preloaded with our most popular visualizations.
  • Once you're ready to start programming on the Cube, make new 3D apps in minutes using Processing or Arduino (a.k.a.Wiring).
  • Create and share your own 3D Cube apps online at CubeTube.org with a click of a button.
  • All of the hardware & software is completely open source under a Creative Commons Attribution-Sharealike 2.5 license.
  • Power: 5V 1A USB power can handle most applications on your Cube - so, this sucker can run off your computer, wall wart, or a battery pack. For super intense visualizations, we've also included a 2A adapter. 100VAC - 220VAC input (you will need to supply your own prong adapter if outside the US)
  • 512 WS2812B RGB LEDs, 100% tested. We ship with a replacement reed of 8 LEDs, just in case.
  • Comes with a Spark Photon for instant WiFi connectivity and blazing processor speeds.
  • Arduino-compatiable -- includes headers for adding your favorite Arduino.
  • Laser-cut acrylic housing.
  • Built-in microphone and 3-axis accelerometer.
  • Assembly instructions here.
  • Product Weight: 1089.0 grams
  • Product Dimensions: 25cm x 22cm x 7cm
Five ways to use your L3D Cube
  • Plug it in, no setup! A standard set of visualizations will automatically start playing when you first plug in your cube. *NEW: you can control the visualizations by tilting your cube, thanks to the included accelerometer!
  • Download new applications from CubeTube wirelessly to your cube with the click of a button.
  • Write your own programs for the Cube in Arduino language or Processing. The programs can be stored in the cube's memory or can be streamed to your cube from a computer over your WiFi network. Here's the definitive guide to programming in 3D in a cube.
  • Connect together multiple cubes and make them interact.
  • Hack it! Add your own sensors for new interactions or make improvements to your cube itself. Everything (hardware+software) is open-source and fully documented so hacking is fun!
Documents
Dimensions 250mm x200mm x70mm
Weight G.W 1095g
Battery Exclude
HSCODE 9405409000
UPC 841454106548
Documentations
Learn
  1. Rating
    100%
    By
1 Item
Show per page
