Pixel v2.5 maker kit
Rating:
100% of 100
control LED matrix easily Bluetooth App available for Android, Mac, Linux etc.
$59.00
In stock
Create LED art installations and wearables using low cost, HUB75 based LED panels. PIXEL supports installations from 32x16, 32x32, 64x32, and 64x64 resolutions. Simply download PIXEL’s free apps for iOS, Android, or Raspberry Pi and send GIF animations, scrolling text, and your own pixel art creations in seconds, no soldering or coding required! As an added bonus, the free apps include 100+ works of original pixel art commissioned for this project.
The PIXEL:LED ART board includes an onboard microSD card allowing you to save your LED art designs locally which will loop indefinitely on the LEDs after your device has been Bluetooth disconnected. Or leave your Android or Raspberry Pi connected and custom code an interactive application displaying art or scrolling messages using our open source example code including support for external sensors (external sensors only supported on Android only firmware).
The PIXEL Maker’s Kit comes installed with the Android only firmware by default supporting LED panels from 32x16 to 64x64 and can easily be flashed via the onboard microSD card for iOS and wearable support too. Refer here for firmware upgrade instructions and note that only PIXEL 2.5 boards purchased after February 2018 have a firmware that can be upgraded via the onboard microSD card.
Firmware Android App
iOS App
Raspberry Pi
Support
Grove Sensors
Low Power
for Wearables
Hub75 LED Panel Support
Android Only Yes No Yes Yes No
32×16, 32×32,
64×32, 64×64
iOS/Android
32×16
Yes Yes Yes No Yes 32×16 Only
iOS/Android
32×32
After writing an animation or scrolling text to PIXEL’s onboard microSD card, your LED design will continue to play and loop after your device has been disconnected. Use PIXEL’s Raspberry Pi integration to create a dynamic installation like displaying different animations based on the weather for example.
The Android only firmware also supports Seeed Grove sensors, specifically 2 analog and 3 digital IO ports. For example, trigger certain animations when someone is near using a proximity sensor. To develop your own app for PIXEL, you'll need to be familiar with Android and/or Java programming and use the PIXEL SDK and sample code.
See the PIXEL Maker’s Kit page for a list of tested and supported HUB75 LED matrix panels and power supply options. This kit does not include an LED matrix panel or power supply/battery. Your choice of power supply will depend on the number of LED Matrix panels in your installation.
For technical support and suggestions, please visit our forum.
Also more information and instructions available at http://ledpixelart.com/maker including links to supported HUB75 LED matrix panels and power supply options.
Dimensions 170mm x120mm x40mm
Weight G.W 156g
Battery Exclude
HUB75 LED Matrix Panel Not Included
Pixel 2.5 PCBA 1
Power Cable 1
A to A USB 2.0 Cable 1
MicroSD Card 1
Blurtooth CSR4.0 USB Dongle 1
Pixel Flat Cable
FPC IDC Cable
HSCODE 9023009000
UPC 841454104964
Customer Reviews
  1.
    Rating
    100%
    Excellent Seller and Product !!! THANKS !!! ++++++++++++
    Review by
    Posted on
  2.
    Rating
    100%
    Did exact what I needed. Did exact what I needed.
    Review by
    Posted on
Product Faqs
Sort by
