Loading...
RoboMaster M3508 P19 Brushless DC Gear Motor
M3508 P19 Brushless DC Gear Motor is a high-performance servo motor, specially designed for small and medium-sized mobile platforms and robots. Compared with traditional square wave drive, the M3508 gear motor features sinusoidal drive used with RoboMaster C620 Brushless DC Motor Speed Controller, which boosts higher efficiency, flexibility, and stability. The gear motor’s reduction ratio is approximately 19:1.
$115.00
Out of stock
Attention
Please note this product is not available for Europe currently. We will update it here when it's ready.
  • M3508 Brushless DC Gear Motor Combo
    Rated Voltage:24 V
    Rotational Speed (without payload):482 rpm
    Max continuous torque:3N·m
    Max rotational speed with a continuous torque of 3N·m:469rpm
    Operating Temperature Range:32°~122° F (0~50° C)
    Weight:365 g
    Outer diameter:42 mm
    Total length:98.4 mm
    Output shaft:Type-D with threaded holes
    Output shaft diameter:10 mm
  • C620 Brushless DC Motor Speed Controller
    Rated Voltage:24 V
    Weight:35 g
    Dimensions(LWH,without cables):49.4×25.8×11.5 mm
    Total length (with cables): 344±15 mm
    Two Signal Modes:CAN bus communication、50-500 Hz PWM signal
    Max Continuous Current:20 A
1 x RoboMaster M3508 P19 Brushless DC Gear Motor
1 x Cable
HSCODE 8501310000
UPC
FCC 1
