the AI Hardware Partner
Toggle Nav
Loading...
Desktop 2 Heads Automatic SMT P&P Machine
Product Feature:Desktop 2 Heads Automatic SMT P&P Machine is the classic of desktop dual-head SMT pick and placement machine
$5,999.00
Out of stock
If you would like to purchase or obtain more information about this item, please email us at: [email protected]
•  Desktop 2 Heads Automatic SMT P&P Machine is the classic of desktop dual-head SMT pick and placement machine. High precision, more reasonable mechanical design, easy operation, stable running, adapting air-operated feeder, automatic vision system, automatic detection materials shortage. Suitable for mounting most of the SMD components, such as 0402 0603 0805 1206 1210 3528 5050 SOP QFN, etc.
Product Features:
•  Drawer type computer and driver integrated, could pull out lightly, convenient for later maintenance.
•  Disassembled chassis, easy to handling.
•  HD industrial camera, precisely identify 0402, 15*15mm and other electronic chips.
•  Intelligent remounting design, when pick materials failed, software will instruct to continue mounting no-stop, record  and unify remounting. It could improve the mounting efficiency .
•  Component auxiliary box design, make components programming and position revising more precisely.
•  Software is easy to understand and use, free upgrade permanently.
Dimensions 1045mm x850mm x650mm
Weight G.W 168000g
Battery Exclude
Max. Circuit Board Area 295x420mm
XY Max. Movement Range 530x550mm
Z Axis Max. Movement Range 20mm
Max. Mounting Speed 6000 cph
Avarage Mounting Speed 5000 cph
Positioning Accuracy 0.01mm
Nozzle Buffering Range 8mm
Power Supply AC220V,50Hz
Compressed Air 0.5~0.7Mpa
Avarage Power 300W
Support Feeding Method Tape feeder,tube feeding,tray IC
Applicable Components 0402, 0603, 0805, 1206, 3528/ 5050/ 3014, diodes, transistors,QFN/SOP/SOT/BGA/ Chip 100 pin or 15mm*15mm
Feeder No. 25
Moter Stepper Moter
Mounting Head 2 Heads
Motion Driving System High speed digital high pressure driver
Component Angle 0~360°,synchronized rotation in motion
Programming Mode Point-to-point programming,visual programming,etc.
Vision Operating Mode Built-in PC,automatically recognize,correct and remount
X/Y Running Mode A new generation of linear interpolation linkage
Air Source Reversal positive and negative pressure switch
Visual Programming Camera Ultra high pixel color infrared
Visual Display 15'' Color HD display
2 Heads Automatic SMT P&P Machine 1
PC 1
Tools bag 1
HSCODE
