the AI Hardware Partner
Toggle Nav
Loading...
4A Motor Shield
The 4A Motor Shield is based on the Freescale MC33932 dual H-Bridge Power IC , which can control inductive loads with currents up to 5
$38.50
Out of stock
  • 10+: $34.65
The 4A Motor Shield is based on the Freescale MC33932 dual H-Bridge Power IC , which can control inductive loads with currents up to 5.0A peak per single bridge. It lets you drive two DC motors with your Arduino/Seeeduino board, controlling the speed and direction of each one independently. You can also measure the motor current absorption of each motor, among other features.
The on board DC/DC converter suport a very wide range of input voltage, and can provide a 5V power supply for the microcontroller board with 100mA maximun current.So, you just need one power supply to drive the motors and power up the logic circuit.
  • Output short-circuit protection (short to VPWR or GND)
  • Over-current limiting (regulation) via internal constant-off-time PWM
  • Temperature dependant current limit threshold reduction
Dimensions 115mm x75mm x25mm
Weight G.W 53g
Battery Exclude
Operating Voltage 6V ~ 28V
DC/DC output 5V 100mA @"5V"pin
Output Current(For Each Channel ) 2A (continuous operation) / 5A(peak)
Output Duty Range Output Duty Range: 0%~100%
4A Motor Shield 1
HSCODE 8538900000
USHSCODE 8471490000
UPC 841454112785
EUHSCODE 8543709099
COO CHINA
RoHS 1
