the AI Hardware Partner
Toggle Nav
Loading...
Motor Shield
This product was replaced by a updated version Motor Shield V2
$19.50
Out of stock
This product was replaced by a updated version Motor Shield V2.0 (SLD01102P).
Motor Shield V2
The Motor Shield is a perfect platform for robotics and mechanical applications. It enables the Arduino to drive two brushed DC motors or one 4-wire two-phase stepper motor. Based on the H-bridge driver Chip L298N motor driver integrated circuit, it requires a 6V to 15V power supply to power the motor and also includes an on-board 5V voltage regulator for powering the main Arduino board. Additional plug and play Grove sensors can be connected to the 13 on-board Grove connectors.
  • Standard Arduino compatible
  • Pulse-width modulated speed control mode
  • 4 direction indicator lights
  • Compatible with Grove plug and play sensors
  • Extra large heat sink helps handle big loads
CAUTION:
The Driver IC and Heat sink may become very hot when working with current more than 1000mA.
Specifications
Item
Min
Typical
Max
Unit
Logic Control Voltage
4.5
5
5.5
V
Motor Supply Voltage
6
15
V
Output Voltage
0
Vinput -1
V
Output Current( For Each Channel)
2000 *
mA
Output Duty range
0%~100%
Dimension
68.5x54.5x29.5
mm
Net Weight
37
g
For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your using of the product.
Documents
Dimensions 0mm x0mm x0mm
Weight G.W 37.29g
Battery Exclude
HSCODE
