the AI Hardware Partner
Toggle Nav
Loading...
Galvanometer motor (SC17-15K)
Rating:
100 % of 100
Galvanometer motor is a lower cost stander parts used in laser equipment, easy to be used and assembled
$69.95
Out of stock
  • 10+: $62.96
Galvanometer motor is a lower cost stander parts used in laser equipment, easy to be used and assembled. it's offer a most cheap, convenient option when you want to controll the light beam
Feature
  • Small volume
  • compact structure
  • convenient installation
  • Analog signal control
  • Scanning Angle: ±30 ( ±20)
  • Rotor inertia: 0.025 gm*cm2, ±10%
  • torque: 2.5 x 104 dyne-cm/amp, ±10%
  • The maximum coil temperature: 100℃
  • The stator coil shell heat resistance: 8℃/W
  • coil resistance: 8.3Ω±10%
  • coil inductance: 153uH±10%
  • The average current carrying: 1.5A
  • response time one step: 0.3ms
  • linearity: 99.0%
  • Repeat accuracy: 15 microradians
  • Size of the lens: 7mm*11mm*0.6mm
  • Mirror reflectivity: >98% @45° ( 380nm-700nm)
Dimensions 145mm x110mm x52mm
Weight G.W 319g
Battery Exclude
Galvanometer motor (SC17-15K) 1
HSCODE 8501109990
USHSCODE 8501104080
UPC 841454116035
EUHSCODE 8501109390
COO CHINA
RoHS 1
  1. Product Quality
    100%
    By
1 Item
Show per page
