Gear (reduction ) motor p12 6V 60RPM
Gear (reduction ) motor,made in Shenzheng, China, pretty good quality, running a speed at 60rpm
- 10+: $7.65
Gear (reduction ) motor,made in Shenzheng, China, pretty good quality, running a speed at 60rpm. All you need to do is connect the postive and negative pole-pin, simple enough for beginners.
Specifications
Operating Voltage: DC 2.4 ~ 6.0V
No Load Speed: 55 ~ 70rmp
No Load Current: 30 ~ 70mA
Max. Efficiency Speed: 40 ~ 52rpm
Max. Efficiency Current: 350 ~ 450mA
Torque: 0.7 ~ 1.2kg.cm
Stall Current: 500 ~ 700mA
Stall Torque: 3.0 ~ 4.0kg.cm
Dimensions | 0mm x0mm x0mm |
Weight | G.W 10g |
Gear (reduction ) motor p12 6V 60RPM | 1 |
HSCODE | 8501101000 |
USHSCODE | 8501104080 |
UPC | 841454109181 |
EUHSCODE | 8501109390 |
COO | CHINA |
RoHS | 1 |
