Loading...
Xadow Audio
Rating:
100% of 100
The Xadow Audio integrates a speaker box and a microphone on one single board
$5.00
Out of stock
  • 10+: $4.75
  • 20+: $4.50
  • More
  • 50+: $4.00
  • Less
The Xadow Audio integrates a speaker box and a microphone on one single board. The speaker unit is rated at 0.7Watt with an impedance of 8 ohm. Unlike the common cone type speakers, the loudspeaker driver used on the Xadow Audio has a flat surface and is mounted in a rectangular enclosure, which enables it to reproduce sounds at an amazing effect.
Include
  • Xadow Audio *1
  • FPC Cable 35 PIN * 2
Features:
  • Open source and modular design
  • Built-in enclosure for speaker
  • Combines speaker and microphone on one board
  • Built-in Xadow Connectors for easy pluggable FPC cables
  • Stackable and chainable with other Xadow Modules
  • Perfect choice for your audio and DIY Phone projects
Speaker Box:
Resonant Frequency: 900 Hz
Impedance: 8±20% Ω
Rated Power: 0.7 W
MAX. Power: 1 W
Frequency Range: 900 Hz to 20 kHz
Microphone:
Microphone Sensitivity: -42dBV Typ.
Max Input Sound Pressure: 130dB SPL
Dimensions:
Speaker: 13mm X 18mm X 4.5mm / 0.51” X 0.71” X 0.18”
Microphone: 2.95mm X 3.76mm / 0.12” X 0.15”
Board: 25.37mm X 20.30mm / 1’’ X 0.8’’
Dimensions 120mm x80mm x7mm
Weight G.W 6g
Battery Exclude
Xadow Audio 1
HSCODE 8518900090
UPC 841454117582
Documentations
Learn
Wiki of Xadow Audio
  1. Rating
    100%
    By
  2. Rating
    100%
    By
2 Item(s)
Show per page
