the AI Hardware Partner
Toggle Nav
Loading...
Xadow - Barometer
The module can measure the air pressure and temperature of the current environment, and you can also converte this signal to a hight information
$10.90
Out of stock
  • 10+: $9.81
  • 20+: $9.27
  • More
  • 50+: $8.72
  • Less
The module can measure the air pressure and temperature of the current environment, and you can also converte this signal to a hight information. If you plan to use Xadow to do a wearable device and measure the height when you climb the mountain , then the module will be your only choice.
Xadow is a though small but perfectly formed Arduino(TM) compatible board series containing several modules. It's a kit extremely suitable for space-sensitive projects such as wearable devices & arts designs, which have higher request on size, weight and flexible cascade connection.
You can find more modules here.
Note: This module is not compatible with any other Xadow version 2 or RePhone modules.
Dimensions 205mm x40mm x9mm
Weight G.W 11g
Battery Exclude
Xadow - Barometer 1
