Loading...
Xadow - NFC Tag
Xadow - NFC Tag is a highly integrated Near Field Communication Tag module,this module is I2C interface,which base on M24LR64E-R,M24LR64E-R have a 64-bit unique identifier and 64 -Kbit EEPROM
$5.00
Out of stock
Xadow - NFC Tag is a highly integrated Near Field Communication Tag module,this module is I2C interface,which base on M24LR64E-R,M24LR64E-R have a 64-bit unique identifier and 64 -Kbit EEPROM.Xadow - NFC Tag attach an independent PCB antenna which can easily stretch out of any enclosure you use, leaving more room for you to design the exterior of your project.
  • Working Voltage: 5V or 3V3
  • Working Current<1mA
  • 2CM max effective range
  • Serve for contactless communication at 13.56MHz
  • ISO 15693 and ISO 18000-3 mode 1 compatible
  • 64-bit unique identifier (UID)
  • Read Block & Write (32-bit blocks)
  • I2C Interface
Documents
NOTE
This module is not compatible with any other Xadow version 2 or RePhone modules.
Dimensions 210mm x65mm x9mm
Weight G.W 11g
Battery Exclude
HSCODE 8517709000
UPC 841454101277
