Laser Keyboard Kit
Rating:
100% of 100
Here comes the latest verion2 designed by RoboPeak, more compact, more reliable and a 3D printed framework! Using lasers to create a virtual keyboard? This seems to be only existing in sci-fi movies
$49.50
Out of stock
Using lasers to create a virtual keyboard? This seems to be only existing in sci-fi movies. Well, with this Laser Keyboard Kit, you will not only be able to tap on laser projections as the keyboard, but also program it to be anything you want, such as a laser multi-touch pad. With a few quick and simple assemblings and calibratings, your laser projection keyboard is ready to glow in the dark!
A laser projection keyboard is a form of computer input device whereby the image of a virtual keyboard is projected onto a surface: when a user touches the surface covered by an image of a key, the device records the corresponding keystroke. The projection is realized in four main steps and via three modules: projection module, sensor module and illumination module. The main devices and technologies used to project the image are a diffractive optical element, red laser diode, CMOS sensor chip and an infrared (IR) laser diode.
This Laser Projection Keyboard Kit V2 is based on the open-source laser keyboard project designed by RoboPeak Team. It works just like a standard keyboard on your PC/MAC with the help of the related signal processing software designed by RoboPeak. The signal processing software also supports turning your laser keyboard kit into a multi-touch pad. As an open-source project, you can freely make any changes/improvement to the current design and go through the implementation detail of the kit.
Application
  • DIY Laser Keyboard
  • Custom interactive input solution
  • Custom touch pad
System Compatibility
  • Windows/macOS
  • QWERTY Keyboard
  • Pure white 3D printed frame
  • Random access to get sexy purple version
  • Laser Safety Classification: Class 1M
  • Integrate custom 170°wide-angle vision camera (driver free) with 790nm infrared filter
  • Linear laser spec: 790nm 10mw
  • Dimensions: 5.5cm x 4cm x 10cm(almost half size of the Laser keyboard v1)
  • System Compatibility: Windows/MacOS
Shipping List
  • Camera Frame 1 unit
  • Laser Keyboard Projector Frame 1 unit
  • Power Board Mounting Base 1 unit
  • Camera (driver free) 1 unit
  • Laser keyboard v2 power board 1 unit
  • Linear laser module 1 unit
  • Laser Keyboard Projector 1 unit
  • M2x8 self-tapping screws 10 units
  • M2x12 self-tapping screws 3 units
  • Cable for camera 1 unit
  • Micro USB Cable 1 unit
Documents
References
Dimensions 0mm x0mm x0mm
Weight G.W 134g
Battery Exclude
HSCODE
Customer Reviews
  1.
    Rating
    100%
    Review by
    Posted on
Product Faqs
Sort by
