Loading...
Thread Drive Pack
This pack included two Fully Threaded Rods, two Linear Motion Shaft, a Universal Joint and a Thread Drive Beam
$12.99
Out of stock
This pack included two Fully Threaded Rods, two Linear Motion Shaft, a Universal Joint and a Thread Drive Beam.(Other beams and the motor in the last picture are not included.)
1.Fully Threaded Rod M4x192mm/M4x280mm
Features:
  • Made of steel, zinc plated.
  • Lengh: 192mm/280mm
Size Charts(mm):
2.Linear Motion Shaft 4x288mm
Features:
  • Made of tainless Steel
  • Can drill into 4mm holes. Compatible with Thread Drive Beam
  • Lengh: 288mm
Size Charts(mm):
3.Thread Drive Beam
Features:
  • Made from 6061 aluminum extrusion, anodized surface. Excellent strength and twist resistance.
  • With thread hole in the middle that compatible with the Fully Threaded Rod.
  • Other holes without thread can be drilled for 4mm shaft.
  • Threaded slot enables easy and flexible connection.
  • Cross-sectional area 8x8mm, length 80mm.
Size Charts(mm):
4. Universal Joint 4x4mm
Features:
  • Material: stainless steel
  • Max deflection angle: 45°
  • Size: D9*Φ4*Φ4*M3*L22mm
  • 2 Headless Set Screw included
Size Charts(mm):
Part list:
  • 1x Fully Threaded Rod M4x192mm
  • 1x Fully Threaded Rod M4x280mm
  • 2x Linear Motion Shaft 4x288mm
  • 1x Thread Drive Beam
  • 1x Universal Joint 4x4mm
  • 2x Headless Set Screw M3x5
Support
If you have any further question for technical support, please contact waker@makeblock.cc or visit forum of Makeblock.
Dimensions 0mm x0mm x0mm
Weight G.W 120g
Battery Exclude
HSCODE 7326901900
Documentations
Learn
