the AI Hardware Partner
Toggle Nav
Loading...
XY-Plotter Robot Kit v2.0 (No electronic)
Introduction: Makeblock XY-Plotter 2
$209.99
Out of stock
  • 10+: $188.99
  • 20+: $178.49
  • More
  • 50+: $167.99
  • Less
Introduction:
Makeblock XY-Plotter 2.0 is a updated version of XY-plotter. With the Processing and GRemote, You can draw amazing pictures with Gcode.
Since we reinforce the structure, the XY-plotter 2.0 is stronger enough to be conversed to MiniCNC, 3D printer, driller, etc. And the movement of the terminal is stable and precise since the improved dual-way transmission mechanism.
Features:
  • Strong aluminum extrusion parts, anodizing surface
  • Two Metal stepper motor with back shaft
  • 12V Solenoid include
  • Closed type bushing block and ball bushing insert for use in linear motion applications
  • Four-bolt aluminum alloy bushing block for a lightweight ready-to-mount installation
  • Synthetic resin retainer plate for accurate ball guidance and low noise
  • Four rows of recirculating balls inside the ball bushing for smooth running
  • Integral lip seals to retain lubricant and protect against contamination
  • Round steel shaft for use with slide units in linear motion applications.
  • Chrome plated for corrosion resistance
  • Case hardened for wear resistance
  • Precision ground for consistent ball bushing radial clearance
Note:
With this kit, you can only build a XY-Plotter without controller. You can use your own electronic parts to drive this.
Part List:
4 × Linear Motion Shaft D8×480
2 x Stepper Motor
30 × Plastic Rivet 4120
6 × Linear Motion Slide Unit 8mm
2 × Stepper Motor Bracket
25 × Plastic Ring 4x7x2mm
1 × Solenoid-12V
4 × Timing Pulley 90T
10 × Plastic Ring 4x8x1mm
2 × Beam 0824-496
8 × Timing Pulley Slice 90T
35 × Screw M4×8
1 × Beam 0824-144
1 × Open-end Timing Belt (3m)
60 × Screw M4×14
3 × Beam 0824-128
3 × Link Rod
2 × Srew M4×30
1 × Beam 0824-96
2 × Shaft Connector-4
40 × Nylong Lock Nut M4
3 × Beam 0824-80
3 × Threaded Shaft 4×39mm
20 × Nut M4
1 × Beam 0808-96
3 × Shaft Collar 4mm
15 × Nylon Cable Ties
1 × General Bracket
4 × Flange Bearing 4x8x3mm
1 × Cross Screwdriver
2 × Bracket 3x6
8 × Headless Set Screw M3x5
1 × Screwdriver 3mm
14 × Bracket 3×3
15 × Countersunk Screw M3x8
2 × Screwdriver 1.5mm
2 × Plate 3×6
Documents:
How to use
The user guide and troubleshooting of XY-Plotter
XY-Plotter Using Gcode Interpreter
Github
Dimensions 0mm x0mm x0mm
Weight G.W 3100g
Battery Exclude
HSCODE 9023009000
