Loading...
Prototyping system for the micro:bit
bbc, micro:bit, education, microbit,
$22.95
Out of stock
This prototyping system for the micro:bit is a great way to start making circuits and making experiments. This gives access to the pins on the bottom of the micro:bit.
Please note: micro:bit is NOT included.
This prototyping system uses the specially designed edge connector breakout board for micro:bit. The micro:bit pins are broken out to a row of solderable pads. The SCL and SDA pins are separated at the edge of the board providing easy identification. The PCB includes a prototyping area with 3V, 0V and unconnected rows that can be soldered to. This allows easy connection of switches, sensors and any pull-up or pull-down resistors etc. as required.
This prototyping system is used in conjunction with a small prototype breadboard. This makes it easy to connect additional components using the included jumper wires. No soldering required.
Note: This kit requires assembly.
Features:
  • No soldering is required
  • Breaks out 21 pins from the micro:bit using the pre-built edge connector breakout board for micro:bit
  • Small prototype breadboard included so you can use additional components
  • Run your own custom code from your micro:bit to interact with external components
Dimensions 160mm x95mm x35mm
Weight G.W 140g
Battery Exclude
small prototype breadboard 1
jumper wires male to male 10
jumper wires male to female 10
Perspex mounting plate 1
edge connector breakout board for micro:bit - pre-built 1
ECCN ERA99
HSCODE 9023009000
Documentations
Learn
