Loading...
Bus Pirate v3.6 acrylic case v1 (DP6037)
Rating:
93% of 100
A clear laser-cut acrylic case kit for the Bus Pirate v3
$3.00
Out of stock
  • 10+: $2.70
A clear laser-cut acrylic case kit for the Bus Pirate v3.6. This case is designed to be simple, cheap, and easy to assemble. The Bus Pirate PCB is sandwiched between two laser-cut acrylic sheets, and the whole assembly is held together with aluminum screws and standoffs.
This is only compatible with Bus Pirate v3.6 that uses a DP6037 standard PCB template.
If you encounter any problems when using this product, here is the forum from which you can get the technical support.
Dimensions 0mm x0mm x0mm
Weight G.W 26g
Battery Exclude
HSCODE 3926909090
UPC 841454111184
Documentations
Learn
  1. Rating
    100%
    Well made. Easy to assemble.
    By
  2. Rating
    100%
    By
  3. Rating
    80%
    Good enclosure
    By
  4. Rating
    80%
    Not compatible with the SOIC Version
    By
  5. Rating
    100%
    By
Items 1 to 5 of 9 total
Page
Show per page
