Bus Pirate v3 probe Kit
Rating:
100% of 100
commonly used 2.54mm spaced pin 10 pin 2*5
$9.99
In stock
  • 10+: $8.99
  • 20+: $8.49
  • More
  • 50+: $7.99
  • Less
This is a interface cable designed for Bus Pirate V3 which can makes it easier to connect the Bus Pirate to a circuit and get hacking.
Dimensions 0mm x0mm x0mm
Weight G.W 21g
Battery Exclude
HSCODE 8544422100
UPC 841454111191
ROHS 1
Customer Reviews
  1.
    Rating
    100%
    Review by
    Posted on
  2.
    Rating
    100%
    Review by
    Posted on
  3.
    Rating
    100%
    Review by
    Posted on
  4.
    Rating
    100%
    Review by
    Posted on
  5.
    Rating
    100%
    Review by
    Posted on
  6.
    Rating
    100%
    Review by
    Posted on
  7.
    Rating
    100%
    Review by
    Posted on
  8.
    Rating
    100%
    Review by
    Posted on
  9.
    Rating
    100%
    Review by
    Posted on
  10.
    Rating
    100%
    Works as it should After printing out a color code table and taped it to my Bus Pirate, everything is easy and fast using this cable.
    Review by
    Posted on
  11.
    Rating
    100%
    Does what it is intended to do, well done. I needed to open the cables a bit further, as i had a small space for uart connectors... worked fine then.
    Review by
    Posted on
Product Faqs
Sort by
  • Question by: admin on 2018-12-18 02:41:31
    Hello Jerry, sorry for the inconvenience brought, this product is only compatible with v3, we will sell v4 cable soon.
    Answer by: admin on 2018-12-18 02:41:31
    In stock now .
    Thanks for your advice .By the way ,could you send the idea to our wiki ? Thanks``
