the AI Hardware Partner
Toggle Nav
Loading...
Phoenard Phoenex Breadboard
Rating:
100 % of 100
This Phoenard board extension can be docked using the bottom 30-pin connector, breaking out the 30-pin connector
$10.00
Out of stock
This Phoenard board extension can be docked using the bottom 30-pin connector, breaking out the 30-pin connector. You can then develop your own electronic designs with or using the circuit prototyping breadboard and jumper wires.
If you want one Phoenard, please visit here.
  • Breadboard mounted on top of standard Phoenex proto
  • Female 2.54 mm headers installed on pin headers
  • Safe operating conditions
    • Temperature: -10 ~ 60 degrees celcius
    • Humidity: 20% - 90%
  • Power
    • Main board voltage: 3v3
  • Accessible pins
    • Analog: 6 analog pins (A0 - A5)
    • Digital: 5 general purpose I/O; supports PWM (digital pins 4, 5, 6, 7, 9)
    • ISP Interface: 6-pin (MISO/MOSI/SCK/SS/RESET/GND)
    • I2C Interface: SDA/SCL
    • Audio: Left/Right/Audio Gnd
    • Serial Interface: Serial 1 (RX0/TX0)
    • Power: 3v3 (main board), 5v (USB power)
  • 1 x Phoenex Breadboard PCBA
Note
This board uses a 3v3 main board voltage and may not be compatible with all 5v sensors and devices. The 5v power on the extension connector is only present when USB power is provided.
A starters guide together with documentation and software examples is available on our website:
Dimensions 90mm x65mm x11mm
Weight G.W 46g
Battery Exclude
HSCODE 8543909000
USHSCODE 8543908885
UPC 841454118633
  1. Product Quality
    100%
    Not used right non but good quality Not used right non but good quality
    By
1 Item
Show per page
