the AI Hardware Partner
Toggle Nav
Loading...
Practical Plastic Enclosure 56x110x160 mm
Rating:
100 % of 100
This product is retired, please consider our Enclosure selection as your alternative choice
$7.50
Out of stock
This product is retired, please consider our Enclosure selection as your alternative choice.
A strong case! With a black belt cross its upper case, it looks like a armed head of a robot! Why don’t you put on two laser eyes for it and turn it into a frightening weapon! Inside the case, we have set two hooks for you to clasp your circuits tightly. And tada, a big hole has been cut out in advanced in case of peripherals. Here are some details about this case:
  • Inner dimension: 52x106x156mm; Out dimension: 56x110x160mm; Thickness: 2mm; four Screw holes : 94mmx130mm, Inner board: 42x84mm
  • Color: a white upper case with a black belt and a blue button case.
  • Made of thick plastic
  • 4 screws are needed to fix the upper and the button
  • A piece of plastic is used to cover the hole for peripherals
Dimensions 0mm x0mm x0mm
Weight G.W 180g
Battery Exclude
HSCODE 3923100090
  1. Product Quality
    100%
    By
1 Item
Show per page
