Loading...
Rotary Encoder with Switch
Rating:
100% of 100
There are total 5 pins on the encoder, 3 of them on one side are for rotary encoding which need a simple circuit to supply DC 5V, the remaining 2 pins go short when they are pressed.
$3.70
In stock
  • 10+: $3.33
  • 20+: $3.15
  • More
  • 50+: $2.96
  • Less
A rotary encoder is a positional sensor for determining the angular position of a rotating shaft. You can use Arduino boards with modules to achieve such function. There are total 5 pins on the encoders, 3 of them on one side are for rotary encoding which need a simple circuit to supply DC 5V, the remaining 2 pins go short when they are pressed. Please refer to the example scheme for more clear understanding.
In the middle of 3 pins' side is COM port connect to GND .
And other pins (A and B same side of GND) separate pull to +5v via 10k ohm resisters .
Connect the A and B directly to Arduino IO pins.
Arduino usage: http://www.arduino.cc/playground/Main/RotaryEncoders
Dimensions 50mm x70mm x11.7mm
Weight G.W 5g
Battery Exclude
Rotary Encoder with Switch 1
HSCODE 8543709990
USHSCODE 8471500150
UPC 841454116608
ROHS 1
Documentations
Learn
  1. Rating
    100%
    By
  2. Rating
    100%
    By
2 Item(s)
Show per page
