the AI Hardware Partner
Toggle Nav
Loading...
The Whistled - A Sound Controlled Relay
It’s interesting to hack one of your appliances or lighting projects into a whistle controlled intelligent one
$25.00
Out of stock
It’s interesting to hack one of your appliances or lighting projects into a whistle controlled intelligent one. The whistled allows you to do so by simply whistling two musical notes. To set it up, you just need to connect your 5.5/2.1mm DC connector on one end and your load on the other.
To grab a sense of how it actually works, check out the presentation video below:
Specifications
  • ESD protected PCB, covered in transparent heat shrinkable tubing
  • Voltage must be between 4.5 and 18V at the input (barrel connector)
  • Reversed polarity protection
  • Max current of 5A
  • 16 bits PWM output
  • SWD pads for programming
  • Listening range of 15m / 50feet
  • Cortex M4 microcontroller performing 80 FFTs / sec
  • Maximum voltage on the screw terminals is 25 Volts (don't forget the flyback diode!)
Dimensions 0mm x0mm x0mm
Weight G.W 9g
Battery Exclude
