the AI Hardware Partner
Toggle Nav
Loading...
Conveyor Belt Kit for Dobot Magician
Dobot,sliding rail,CNC,education,Conveyor Belt
$559.00
Out of stock
Simplest mini production line
The Conveyor Kit for Dobot Magician makes you have a complete production line simulation. Conveyor belt with adjustable speed, distance and color sensor, combined with the powerful and programmable Dobot Magician, these are the ideal essentials for you to create a highly effective simulated production line, or even to apply to actual factory scenes.
Programmable switch and speed, stable running, this is our most ideal selection for you.
Accurately inspect object position, suitable for object recognition and distance check.
The accurate and responsive tool for you to effectively select and categorize objects.
These colorful wooden cubes are easy to grab, move and pile, the ideal material for you to get a grip of conveyor controlling.
Dimensions 700mm x215mm x60mm
Weight G.W 4200g
Battery Exclude
Payload 500g
E ective delivering distance 600 mm
Maximum speed 120 mm/s
Maximum acceleration 1100 mm/s²
Distance measuring
Measurable range 20 ~ 150 mm
Signal Analog Output
Input 4.5 – 5.5 V
Input 20 ~ 150 mm
Detectable non-glowing object
White LED embedded, on/o controllable
Conveyor Belt 1
Distance Sensor 1
Color Sensor 1
Wood Block 1
HSCODE 8428330000
USHSCODE 84283300
COO CHINA
RoHS 1
