JavaScript seems to be disabled in your browser. For the best experience on our site, be sure to turn on Javascript in your browser.
Shop
This Kit is a great choice for learning robotics, electronics and Arduino programming. It contains mechanical parts and electronic modules for you to start exploring the robot world, it can be used to build a robot tank or a three-wheel robot car.
With the following electronic modules: Me Orion, ultrasonic sensor, IR remote controller and IR receiver, an IR controlled robot or an ultrasonic obstacle-avoiding robot can be build. The Me series electronic modules are easy-to-use, very friendly to beginners.
Perfect for beginners learning robotics, electronics and Arduino programming.
Build a Robot Tank or a Three-Wheeled Robot Car.
Aluminum extrusion structure.
Easy wiring, no soldering required.
The battery of IR Remote Controller will be taken to assure safe transport, you may need to buy it by yoursalf. The battery size is CR2025. Sorry about the inconvenience.
No.
Part Name
QTY
1
Beam 0824-96
2
Beam 0824-128
3
Beam 0824-144
4
Plate 3x6
5
Bracket 3x3
6
Bracket P3
7
DC Motor-25 Bracket B
8
Caster Wheel
9
DC Motor-25 6V/185RPM
10
Shaft Connector-4mm
11
Timing Pulley 90T
12
Tyre 68.5x22mm
13
Track
38
14
Track Axle
15
Threaded Shaft 4x39mm
16
Shaft Collar 4mm
17
Flange Bearing 4x8x3mm
18
HEX Screwdriver 2.5mm
19
Cross Screwdriver 3mm
20
HEX Allen Key 1.5mm
21
Wrench 7mm&5mm
22
Socket Cap Screw M4x8-Button Head
23
Socket Cap Screw M4x14-Button Head
24
Countersunk Screw M3x8
25
Headless Set Screw M3x5
26
Nut M4
27
Nut M8
28
Nylon Stud M4*30
29
Plastic Rivet R4060
30
Plastic Rivet R4120
31
Plastic Ring 4x7x2mm
32
Me Orion
33
Me Ultrasonic Sensor 3.0
34
Me IR Receiver V2.1
35
New Me IR Remote Controller
36
6P6C RJ25 cable-20cm
37
6P6C RJ25 cable-35cm
USB 2.0 A-Male to Micro B-Male Cable
39
Base Bracket B
40
Battery Holder for (6)AA
Arduino programming
Arduino Library
Scratch for Robot
If you have any further question for technical support, please contact waker@makeblock.cc or visit forum of Makeblock.
