the AI Hardware Partner
Toggle Nav
Loading...
Grove - Line Finder to Build Arduino Line Follower Robot
Grove - Line finder help you design line-following robotic projects easily and quickly. Those eye-like sensors on the board are actually IR emitting LED and sensitive phototransistor.
$3.90
Out of stock
  • 10+: $3.51
  • 20+: $3.32
  • More
  • 50+: $3.12
  • Less
Grove - Line finder help you design line-following robotic projects easily and quickly. Those eye-like sensors on the board are actually IR emitting LED and sensitive phototransistor. When the phototransistor detects the reflected infrared light from the IR emitting LED, it will output a digital signal, which changes from HIGH to LOW.
A line-following robot can sense a black line by IR emitting LED and sensitive phototransistor, then they will send the signal to microcontrollers. Finally, your robot will drive the motor according to the output of the sensors.
Feature
  • Grove compatible interface
  • Small size
  • 5V DC power supply
  • Indicator LED
  • Digital output
  • Distance adjustable
What is Grove?
Grove makes it easier to connect, experiment, and simplify the prototyping process. No jumpers or soldering required. We have developed more than 300 Grove modules, covering a wide range of applications that can fulfill a variety of needs. Not only are these open hardware, but we also have open-source software.
Note
Please visit our wiki page for more info about this product. It will be appreciated if you can help us improve the documents, add more demo code or tutorials. For technical support, please post your questions to our forum.
Dimensions 0mm x0mm x0mm
Weight G.W 6g
Battery Exclude
HSCODE 9031900090
USHSCODE 9027106000
UPC 841454108030
ROHS 1
