the AI Hardware Partner
Toggle Nav
Loading...
Adjustable IR Reflection Sensor(3- 80cm)
Rating:
100 % of 100
The Adjustable IR Reflection Sensor consists of a set of infrared transmitter and infrared receiver
$6.90
Out of stock
  • 10+: $6.21
  • 20+: $5.87
  • More
  • 50+: $5.52
  • Less
The Adjustable IR Reflection Sensor consists of a set of infrared transmitter and infrared receiver. It is widely used in robot to avoid obstacles, interactive media, industrial assembly line, and many other occasions. Its detection distance can be adjusted in the range of 3- 80cm according to the demand. The normal status is high, it turns into low when there are obstacles. In addition, there is a light behind the detection probe used for showing the detection status.
  • Adjustable detection distance
  • Low consumption
  • Compact size
Specifications
  • Power supply: 5V
  • Working current: <100mA
  • Detection distance: 3- 80cm
  • Diameter: 17mm
  • Length: 45mm
  • Wire length: 45CM
Pinout
  • Red - V+
  • Yellow - Signal
  • Green - GND
Dimensions 0mm x0mm x0mm
Weight G.W 12g
Battery Exclude
HSCODE 9031809090
  1. Product Quality
    100%
    By
  2. Product Quality
    100%
    Excellent Seller and Product !!! THANKS !!! ++++++++++++
    By
2 Item(s)
Show per page
