the AI Hardware Partner
Toggle Nav
Loading...
G5&4" Water Flow Sensor
Water flow sensor consists of a plastic valve body, a water rotor, and a hall-effect sensor
$29.50
Out of stock
  • 10+: $26.55
  • 20+: $25.08
  • More
  • 50+: $23.60
  • Less
Water flow sensor consists of a plastic valve body, a water rotor, and a hall-effect sensor. When water flows through the rotor, rotor rolls. Its speed changes with different rate of flow. The hall-effect sensor outputs the corresponding pulse signal. This one is suitable to detect flow in water dispenser or coffee machine.
We have a comprehensive line of water flow sensors in different diameters. Check them out to find the one that meets your need most.
  • Compact, Easy to Install
  • High Sealing Performance
  • High Quality Hall Effect Sensor
  • RoHS Compliant
Specifications
  • Dimension: 120*55*51mm(thickness), DN32(Outside: 42.4mm, inside:32mm)
  • Mini. Wokring Voltage: DC 4.5V
  • Max. Working Current: 15mA (DC 5V)
  • Working Voltage: DC 5V~24V
  • Flow Rate Range: 0~120L/min
  • Load Capacity: ≤10mA (DC 5V)
  • Operating Temperature: ≤80℃
  • Liquid Temperature: ≤120℃
  • Operating Humidity: 35%~90%RH
  • Water Pressure: ≤2.0MPa
  • Storage Temperature: -25~+ 80℃
  • Storage Humidity: 25%~95%RH
Documentations
Dimensions 130mm x70mm x50mm
Weight G.W 203g
Battery Exclude
G5&4" Water Flow Sensor 1
HSCODE 9026100000
ROHS 1
