M11*1.25 Water Flow Sensor
Rating:
80% of 100
Water flow sensor consists of a plastic valve body, a water rotor, and a hall-effect sensor
$9.50
In stock
  • 10+: $8.55
  • 20+: $8.08
  • More
  • 50+: $7.60
  • Less
Water flow sensor consists of a plastic valve body, a water rotor, and a hall-effect sensor. When water flows through the rotor, rotor rolls. Its speed changes with different rate of flow. The hall-effect sensor outputs the corresponding pulse signal. This one is suitable to detect flow in water dispenser or coffee machine.
We have a comprehensive line of water flow sensors in different diameters. Check them out to find the one that meets your need most.
  • Compact, Easy to Install
  • High Sealing Performance
  • High Quality Hall Effect Sensor
  • RoHS Compliant
Documentations
Dimensions 0mm x0mm x0mm
Weight G.W 31g
Battery Exclude
Mini. Wokring Voltage 4.5V (DC)
Max. Working Current 15mA @ 5V DC
Working Voltage 5V ~ 24V (DC)
Flow Rate Range 0.3 ~ 6L/min
Load Capacity ≤ 10mA (DC 5V)
Operating Temperature ≤ 80℃
Liquid Temperature ≤ 120℃
Operating Humidity 35% ~ 90%RH
Water Pressure ≤ 0.8MPa
Storage Temperature -25 ~ +80℃
Storage Humidity 25% ~ 95%RH
Thread size M11*1.25
M11*1.25 Water Flow Sensor 1
ECCN ERA99
HSCODE 9026100000
USHSCODE 9026102040
UPC 841454116127
ROHS 1
Water flow sensor consists of a plastic valve body, a water rotor, and a hall-effect sensor. When water flows through the rotor, rotor rolls. Its speed changes with different rate of flow. The hall-effect sensor outputs the corresponding pulse Signal.
Customer Reviews
  1.
    Rating
    80%
    Review by
    Posted on
Product Faqs
Sort by
