Non-invasive AC Current Sensor (15A max)
Rating:
100% of 100
Input Current: 0~15A AC Output Mode: 0~1V Non-linearity: ±3%
$6.90
In stock
  • 10+: $6.21
  • 20+: $5.87
  • More
  • 50+: $5.52
  • Less
What is CT sensors
Current transformers (CTs) are sensors that are used for measuring alternating current. They are particularly useful for measuring whole building electricity consumption (or generation for that matter).
The split core type such as the CT in the picture above, is particularly suitable for DIY use it can be clipped straight on to either the live or neutral wire coming into the building without having to do any high voltage electrical work.
Applications
  • Suitable for the current measuring
  • Monitoring and protection of AC motor
  • Lighting equipment
  • Air compressor
  • Input Current: 0~15A AC
  • Output Mode: 0~1V
  • Non-linearity: ±3%
  • Build-in sampling resistance(RL): 124Ω
  • Resistance Grade: Grade B
  • Work Temperature: -25°C ~ ﹢70°C
  • Dielectric Strength(between shell and output): 1000V AC/1min 5mA
  • Leading Wire in Length: 1m
  • Open Size: 13mm x 13mm
  • Fire resistance property: in accordance with UL94-VO
Dimensions 79mm x63mm x27mm
Weight G.W 71g
Battery Exclude
ECCN ERA99
HSCODE 9030899090
USHSCODE 90303338
UPC 841454105473
ROHS 1
Customer Reviews
  1.
    Rating
    100%
    Review by
    Posted on
Product Faqs
Sort by
