Loading...
Non-invasive AC Current Sensor (5A max)
Rating:
100% of 100
Input Current: 0~5A AC Output Mode: 0~1V Non-linearity: ±3%
$6.90
In stock
  • 10+: $6.21
  • 20+: $5.87
  • More
  • 50+: $5.52
  • Less
Introduction:
What is CT sensors
Current transformers (CTs) are sensors that are used for measuring alternating current. They are particularly useful for measuring whole building electricity consumption (or generation for that matter).
The split core type such as the CT in the picture above, is particularly suitable for DIY use it can be clipped straight on to either the live or neutral wire coming into the building without having to do any high voltage electrical work.
Features:
Applications
  • Suitable for the current measuring
  • Monitoring and protection of AC motor
  • Lighting equipment
  • Air compressor
Specification:
  • Input Current: 0~5A AC
  • Output Mode: 0~1V
  • Non-linearity: ±3%
  • Build-in sampling resistance(RL): 372Ω
  • Resistance Grade: Grade B
  • Work Temperature: -25°C ~ ﹢70°C
  • Dielectric Strength(between shell and output): 1000V AC/1min 5mA
  • Leading Wire in Length: 1m
  • Open Size: 13mm x 13mm
Fire resistance property: in accordance with UL94-VO
Dimensions 80mm x62mm x27mm
Weight G.W 73.5g
Battery Exclude
HSCODE 9030899090
USHSCODE 90303338
UPC 841454105428
ROHS 1
Documentations
Learn
  1. Rating
    100%
    By
1 Item
Show per page
