Loading...
One Wire Temperature Sensor - DS18B20
Requires only one wire for data interface Waterproof Grove compatible 3.3V and 5V dual mode Wide temperature range for measurement
$7.50
In stock
  • 10+: $6.75
  • 20+: $6.38
  • More
  • 50+: $6.00
  • Less
This 2m long One Wire Temperature Sensor - DS18B20 has a waterproof probe and long wire shape, suitable for immersive temperature detection. The chip inside this sensor is DS18B20 which is widely adopted.
The original one includes three wires inside. You need to add an extra resistance to get it working. So for this sensor, we adjusted it into a Grove port and had a resistance pre-assembled inside so that you can use it as a regular Grove sensor. This makes it an easy connected one wire temperature senor for Seeeduino,which is derived from Arduino and compatible with all Arduino platforms.
For convenience, we have listed some resources at the bottom of this page. You can also find tons of resources from Google or other OSHW communities.
Caution
The cable part cannot be put under temperature higher than 70°C for a long time.
  • Requires only one wire for data interface
  • Waterproof
  • Grove compatible
  • Accepts 3.0V to 5.5V power supply
  • Wide temperature range: -55°C to +125°C
  • High accuracy: ±0.5°C( -10°C to +85°C)
Documents
Dimensions 0mm x0mm x0mm
Weight G.W 54g
Battery Exclude
One Wire Temperature Sensor 1
HSCODE 9025199090
USHSCODE 9025900600
UPC 841454105299
Documentations
Learn
With so many temperature sensors available, how should we choose the right one for our Arduino project? Well, it really depends on several factors such as what we are measuring, the degree of accuracy we need and where we may be measuring the temperature.
This is the wiki page for this product, which will show you how to use the product, as well as details about the software and hardware.
As a foodie, I have always longed for some sous vide dishes. However I haven’t got a chance to try it yet. [Sous vide (/suːˈviːd/) comes from French, means "under vacuum", a method of cooking in which food is sealed in airtight then placed in a
A solar boiler is great because it gives you hot water using free-sun-energy, but what if there is not enough sun or someone already used all the hot water ? This project helps you take the right decision. It warns you when you run out of hot water and al
